Macros [Tab 18]
This display allows you to edit macros. Macros are comprised of any series of button presses (both hard and softkeys), screen commands and events. Eos provides you with the macro feature to simplify complex or repetitive console programming and operating tasks that you perform often.
Macro editing is accomplished from the macro editor display. As an alternative to recording your macro in live, you may create it from this display instead.
Macros can be opened in a standalone tab from the Workspace Layout Menu or by using [Tab] & [1][8].
This display can also be accessed:
  • Using [Macro] [Macro].
  • Via a connected keyboard with MM.
  • From the Central Information Area (CIA) under Browser > Record Target Lists > Macro Editor.
Overview
When you record the series of button presses to a new macro, you can later play it back by simply pressing the macro direct select button, running it from a linked cue, accessing it from a connected show control system, remotely triggering the macro, or running it from another recorded macro.
You may create up to 99,999 macros either from live, using the macro [Learn] mode to record a sequence of keystrokes as you perform the operation, or you can create a macro from within the macro editor display, entering and editing keystrokes into the macro content editor without actually executing the instructions.
When macros are running, Eos waits 60 ms after each use of [Enter] so that commands run smoothly in their intended order.
Macro Editor Display
The macro editor display contains a listing of all recorded macros including labels and the contents of the macros stored. All macro editing is accomplished from the macro editor display.
The display is divided horizontally, the top portion displays the macro contents in detail while the bottom portion lists all macros, including the label and contents.
While in the macro editor display, any numeric entry on the command line is assumed to be a macro number. If the macro number entered already exists and [Enter] is pressed, the macro list will page to the selected macro and the macro content detail section will display all of the contents of the selected macro. If the macro number entered does not exist in the list and [Enter] is pressed, an empty macro will be created with the specified macro number.
While in the macro editor display, the following functions may be performed using the control keypad and softkeys:
  • [Label] - when a macro is selected and [Label] is pressed, the alphanumeric keypad will display on the CIA. Label the macro and press [Enter].
    • [1] [Label] <name> [Enter] - labels macro 1
  • {Icon} - macros can be assigned Icons, which can be configured to appear on the direct select button in Direct Selects (Tab 4) or Custom Direct Selects (Tab 39).
  • {Color} - assign colors ({Red}, {Green}, or {White}) or {Dark} to a macro. {Dark} assigns no color to the macro. The colors will display beside the macro name in a direct select, and/ or if that macro has been assigned to one of the customizable hardkeys on Eos Ti, Gio, Gio @5, and RPU.
    • There is also a {Toggle Blink} softkey. By default a customizable hardkey will blink when the macro assigned to it is running. This softkey will turn off the blinking if it is enabled and a BD will display in the color column when blinking is disabled.
    • Not available on Element Classic
  • [Delete] - when a macro is selected and [Delete] [Enter] is pressed, you will be prompted to confirm the deletion of the selected macro. To confirm press [Enter], to abort press [Clear].
    • [1] [Delete] [Enter] [Enter] - deletes macro 1 from the list.
  • [Copy To] - when a macro is selected and [Copy To] is pressed, you will be prompted to enter the macro number that you want to copy the contents of the selected macro to. You will be prompted to confirm the copy process, press [Enter] to confirm or [Clear] to abort the copy to process.
    • [1] [Copy To] [6] [Enter] [Enter] - copies the entire contents of macro 1 to macro 6.
  • {Edit} - when a macro is selected and {Edit} is pressed, you will have entered edit mode for the selected macro. See Editing Macros. Three notable changes to your macro editor display include:
    • a blinking cursor in the macro content detail portion (top) of the display.
    • ”Press [Select] to save or [Escape] to cancel changes” displays above the command line.
  • {Move To} - allows you to move and reorganize your macros anywhere in the macro list numerically. You can access {Move To} by pressing [Copy To] twice.
    • For instance, if you have macros 1 through 5 in the list, and you want to move/ change macro 1 to macro 6 so that your most commonly used macros are first in the list, you would press [1] {Move To} [6] [Enter]. This leaves only macros 2 through 6 in the list.
  • {Mode} - allows you to assign different modes for the macro to run in. There are three modes: background, foreground, and default.
  • {Default}
    • When a macro in default mode is run manually, it runs in the foreground(i.e., the command line) on the device that fired it. When a macro in default mode is executed by a cue or via show control, it runs in the background on the master device.
    • Running a macro on a master device only matters when the macro changes the displays of the device it runs on such as snapshot and flexichannel macros.
  • {Background}
    • When a macro in background mode is run manually, it runs on the device that fired it but will not affect its command line.
    • A macro in background mode that is run from a cue or via show control will run on the master device but will not affect the master's command line.
    • When a background macro is running and includes a link to another macro, or is currently waiting, pressing the [Macro] button will stop it.
  • {Foreground}
    • When a macro in foreground mode is run manually, it runs on the device that fired it and affects its command line.
    • If a foreground mode macro is fired via show control, it runs on the master device and will affect its command line.
    • If a cue fires the macro, it will run on the device whose user last pressed [Go] on that playback. If a foreground macro is fired from a cue that is executed from another cue list, the macro will run on the device that last pressed [Go] on the cue’s playback but not the playback that triggered the executed cue.
  • {Target Device} - A macro can have a Target Device assigned to it. This allows a cue to execute a macro only on a certain console.
    • The Target Device can be a device name or User ID. These are assigned to a macro in the Macro Display by using the {Target} softkey and either selecting {Device} and {User}. Pressing {Target} will also display a list of connected devices and additional target options.
    {SC Learn} - enables or disables excluding specific macros from being learned as show control events. See Adding Timecode Events > Using Learn.
